1 - 3 of 3 Posts
Hey,
I've tried to reset the service indicator on the bike with my vdst but when i click on the button I assume did it it does not work. am i right in thinking its the service light button? I do get a lot of disconnects via my crappy old laptop so thinking this might not help.
Cheers
Hey,
Cheers
When you turn your bike on, connect within 10 seconds or the ecu goes to sleep.
When you click on the maintenance light it(under actice settings) should say connecting to ecu. Click ok
Maintenance light should go out.
Turn off bike then turn back on again.
If the maintenance light does not go out try again, I remember I had to try it a few times before it worked.;)
sweet i'll test it out. I tried 2 times but got bored and went for a ride. :)
1 - 3 of 3 Posts
