Ok so been a while since I have put anything on here as FB and social media give us plenty of options for troubleshooting and advice.
So when I turn the hot grips on the back light in the LCD pulses off and on. If I pull the front brake lever in the tacho pulses from idle revs to zero revs in time with the LCD back light. Crazy. Its the same timing as you would see the Oxford grips blue light flashing if the voltage is too low and the grips will not function. This happens when the grips are functioning correctly.
Do I have a bad earth somewhere? The grips are wired earth directly to the battery and positive to the spare connection on the DD headlight wiring so they cannot run with the key off.
Any ideas....
Cheers, Nick.
Any ideas....
Cheers, Nick.
