1 - 10 of 10 Posts
I'd ordered a tail tidy from my dealer but it didn't arrive last Thursday when they said it would and weren't sure when it would be in.:mad:
So I made my own outta thin Ally checkerplate.:rolleyes:
All I need to do now is ditch the giant number plate(and the one in the pics has been cut down around the edges!!!!!:eek:)
With a normal wood saw ,I might add !!:abduct:
Discussion Starter · #8 ·
To be honest,the indicators were the only ones they had that would pass the massive number plates they issue us with over here,and that was with a little modification also.:rolleyes:
I did try some led flashers in the tail unit but they were useless as they couldn't be seen from behind...:eek:
So this was the only alternative for the minute...;)
And I quite like the homemade look...I mean,isn't that what a StreetFighter is about???Individuallity????
Discussion Starter · #10 · (Edited)
haha he punked you
I like the underside shot really shows the effort you put into it. Oh and you cheated getting out the grinder!
Did you just start with a piece of diamond plate or something for the bracket?
PUNKED
http://www.urbandictionary.com/define.php?term=punked
Just got some checker/diamond alluminium plate from B&Q(Home Depot to you'all)
http://www.diy.com/diy/jsp/bq/nav.j...refview=search&ts=1243575958987&isSearch=true
Marked out the top shape from the original hanger,allowed about 3/4" for the thickness of the original.I also drew on the indicator brackets ,cut out the shape and bent it in the vice,with a little help from a hammer to flatten down the edges.drilled the appropriate holes to fix to the bike and for the indicators.
Then I smoothed off the edges with a file and some wet and dry....
Very Simple really.:rolleyes:
1 - 10 of 10 Posts
