Status
Not open for further replies.
Exceptional bike that I have spent a ton of time and money on. No stories (other than its constrution) whatsoever.
Roughly 8,400 miles with roughly 3,000 on the majority of the modifications / add-ons. Here are the details:
Pics can be found here: 02 Duc M944 by mcd432_photos | Photobucket
Add-on's that I can recall, as I know I have missed some, are as follows:
- 944 Kit Installed
- Heads / Valves serviced by DucShop
- Lightened Flywheel (Weighs 1.5 Lbs and secured by Corse Dynamics jam nuts)
- Custom fabricated skid plate belly protector
- SpeedyMoto Leggero belt covers
- SpeedyMoto 5-spoke clutch cover
- Billet pressure plate (Paulimoto I believe?)
- Billet oil fill plug (don’t recall who the mfr is?)
- Dynojet Power Commander with custom dyno tuned map
- BMC high flow air filter
- Shorai lithium battery
- Powerlet large gauge starter cables
- Polished stock exhaust header
- Termignoni carbon fiber Exhaust
- Front Forks: Ohlins 25mm internals serviced / set-up by Cogent Dynamics
- Rear Shock: Ohlins serviced by Cogent Dynamics
- Toby steering damper
- All Balls taper steering head bearings
- Billet steering stem nut (don’t recall who the mfr is?)
- Rizoma handlebar
- Pazzo billet adjustable brake and clutch levers
- Mad Duc billet clutch and brake reservoir covers
- CRG bar end mirrors
- Machesini 5-spoke rims with Pirelli Diablo Rosso tires. Roughly 50% tire life left
- 520 gold chain conversion (15 tooth front Afam and 39 tooth Supersprox rear sprockets)
- Corse Dynamics voltage regulator relocator
- Corse Dynamics crankcase breather kit
- Billet axle plate adjusters
- Custom paint work
- Extensive powder coating (virtually everything but the frame and the engine cylinders – high temp professional coating)
- Sargent seat
- Shift Tech carbon front fender (I believe?)
- Carbon fiber rear fender (don’t recall the mrf?)
- Carbon beer tray (don’t recall the mrf?)
- Zero Gravity windscreen
- Rizoma LED directionals
- Billet foot pegs (don’t recall the mfr?)
- H4 bright headlight bulb
Silly (see list above) asking price is: $5,000
Bike is located outside of Chapel Hill, NC
Fire away with any questions you may have
Thanks for all the interest and kind comments, guys! The bike has been sold to a guy local to me.
Mods please delete post and, likewise, thanks for all!
Status
