1 - 2 of 2 Posts
2000 900SSie
the highbeam button doesnt "click" when pressed and the high beam stays on all the time.
Judging by the picture on the switch I assume this is not normal.
I took the switch apart to see if I could figure out why it wont go back to the Low position.
Did not figure that out...
Any idea if this switch can be purchased anywhere without buying the whole thing housing and all?
I had same issue with ST4, switch looks different but reason for that was old grease in mechanism. I simply melted it with wd 40 or gun oil, i don't remember. Sticky grease prevented it work properly.
1 - 2 of 2 Posts
