I went with LED instead of HID and am very happy with the results. Lower temperature and less space required for wiring and ballast.Hi, for those who installed HIDs for their headlight, where did you hide the ballast? Everything is so tight up there, I’m having a hard time find a spot. thanks in advance.
And - generally - they have a more accurate reproduction of the focal point of an incandescent bulb than a HID, so produce a more consistent cutoff, and diffuse the light above the cutoff less, which pisses off other motorists less...People still convert to HID's? Why?
LED's are cheaper, there's no ballast to install, they generate less heat, they draw less power, they last up to 5X longer, they are shockproof with zero moving parts or filaments.
