Hi output battery
1192 9
Anyone have any suggestions for a higher output battery than the stocker in a modded (cams, oversize valves, ported heads, 944, ti rods lightened crank) 93 900ss
1 - 10 of 10 Posts
Old Wizard
Odyssey PC680MJ
Compared to the to the original equipment battery it's a much stronger battery
Battery Family: Standard lead-acid
Battery Type: Yuasa YB16AL-A2
Capacity: 16 AH
Dimensions: 8.125" x 2.8125" x 6.4375"
Weight: 8.6 lb dry, 11.5 lb with electrolyte
C.C.A.: 200
Battery Family: Sealed, dry cell
Battery Type: Odyssey PC680MJ
Capacity: 19 AH
Dimensions: 7.3" x 3.1" x 6.7"
Weight: 14.7 lb
C.C.A.: 280
Get an on/ off switch for your headlight, it'll help a lot.
1 - 10 of 10 Posts
