1 - 2 of 2 Posts
So I found a used short shaft cross mouted ohlins steering damper part number Sd1690. I was wondering if you guys know if it will work with the ducabike mounting brackets for a hypermotard 796. The thing is the used damper listing has it as a short shaft and I have never heard of that and I'm wondering will it not work with the hyper since we have a wider range of movement. :confused:
A ways back I was looking to get the ohlins and motowheels said the ducabike brackets didnt fit very well. I also believe it used one of the longer universal ohlins steering dampers so it may be risky.
1 - 2 of 2 Posts
