Hi, i new to this forum, i hope you can help me with my 1980 900ss.
When i bought the bike it was fitted with a cartridge oil filter and an oil cooler, which worked well.
However, i want to revert back to standard.
I have unplumbed the pipes and taken the oil filter off. There was a round manifold under the filter where the oil pipes screwed in.
So, plugged up the feeds to the cam boxes. Took heads off to ensure the oil feeds were clear. Tried to fit a standard oil filter and found that the engine casting has been machined down by about 20mm.
What i need is a picture or a drawing of the standard casting dimensions so that i can machine a ring which replaces the amount taken off.
Hope you can help
Stephen
Hope you can help
Stephen
