Hey just wanted to stop in and introduce myself. I have an 05 999. I actually just swapped out the pressure plate today . But I'm having a bit of an issue
Ive looked up several how to write ups and videos on changing out my pressure plate. I got everything pulled off and the clutch rod came out with the pressure plate(obviously). But also there was this little free floating ring that came out with it. None if the write ups mention it. I have no idea what ut is and Don't want to go further until I know what it is. It looks like a ferrite ring in size and shape and the diameter is slightly wider than the entire rod. So it can easily fall off the rod. Do I install it with the new plate or toss it?
Super Moderator
I would have definitely posted in another area but the forum wouldn't allow me. Thank you for the insight on my issue :)
