Hepco Becker Hard Luggage installation
2728 4
I've just finished installing the Hepco Becker touring kit on my GT. It wasn't perfectly simple, since tolerances seem to vary a lot on the Ducatis, but the HB mounts have some tolerance forgiveness built in, which helps.
The HB Panniers are NOT compatible with the Ducati Luggage Rack. The Panniers may not work with other sport classics than the GT (due to using the muffler/passenger peg mounts), but I'd be surprised if the luggage rack doesn't work for the dual shock versions of the Sport.
I've attached the instructions below, for reference.
The main load-bearing brace for both the rack and the panniers uses the front two bolts that hold the rear fender assembly in place. If you have saved that assembly (or the WASP rear-end uses it, or replaces it), then you should be good.
