you should, with patience, be able to loosen the nuts insitue you do know that one of the nuts is a left hand thread dont you.
More heat!!! Even if you have to take the linkage off of the bike, that will be the best way to free those bolts.pusher748 said:Well after soaking with PB Blaster, it's still seized. I also tried some heat with no results. I guess the linkage is going to have to come off. The manual says that I need to remove the rear wheel and shock in order to remove the linkage. Is that accurate?
Thanks again for the help.
