First time post here. I just traded up from a Monster to a 2000 748s. Love the bike, but after picking the bike up I noticed that the coolant level was low (or even empty), I mixed up some coolant, distilled water and water wetter to add, and it all came tumbling out from some mystery location. I can't tell if there is actually fluid in the radiator, or if leak is from the radiator, or if there's a loose drain plug or if its from the plastic reservoir itself. My guess is the latter since I've now read that this is quite a common occurence on these bikes.
Is this an easy DIY job? If so, how do I do it? Does it require removing the triple? Or do I remove just the tank and airbox? Thanks in addvance for your help.
BTW - just found a similar post on this for a 916 which helps a little. How much is a bottle/reservoir from the dealer?
