1 - 6 of 6 Posts
Hi. Got a leaking carb. Can someone tell me the correct float bowl gasket part number and where to buy them (my google search sent me to Ebay with sellers in Germany or the UK - I'm in California - and I'm not even sure they're the right gaskets)? Its a 1995 900ss with the Mikuni carbs. Thanks.
You ought to check float level and also replace the gasket under the fuel seat castings. If it leaks unmetered fuel goes around the needle and seat and into the float bowl. All of mine were leaking.
1 - 6 of 6 Posts
