I posted this over on the SF forum, but after pulling up the 848 diagram, I see that the clutch push rod is also run on the 848 and hoping that someone here might know.
The push rod has a pin and a plastic piece on it. I am wondering if anyone know if I can simply not use the pin and ditch the plastic piece to use an aftermarket clutch slave.
thanks in advance !
http://www.ducati.ms/forums/138-streetfighter/137990-help-aftermarket-slave-clutch.html
