I have a 2015 SF848 and recently have encountered the following error codes and issue:
P0141
Lambda sensor heater front cylinder
- short circuit positive
- open circuit
- short circuit negative
P0335
Crankshaft sensor
- sensor malfunction
P0560
ECM power supply
- Circuit malfunction
P0135
- circuit malfunction
Blinking fuel gage
Happens sporadically
I installed a new battery over the winter and had it trickle charging until now. The engine runs fine and it starts fine. I erased the codes and went for a 30min drive and gave it some power. All errors were gone except for P0560.
NOTE: I have an SC Project CRT exhaust installed 3 years ago. Required flashing of the ECU which I did (flashed termi map), and install Ducee to remove check engine light for servo motor.
I looked online, but can't find anything specific. Any help or advice would be appreciated.
P0141
- open circuit
P0335
Crankshaft sensor
P0560
ECM power supply
P0135
Blinking fuel gage
