I have an '02 ST4S and I'm getting coolant leaking from this rubber connection, I believe it called the cooler-heads hose. I tried putting a new hose and clamp several times to no success. It only leaks when the bike is running at speed, actually spraying out under pressure is more accurate. It won't leak at all while idling in the garage, also while bike is sitting over night no puddles under the bike. any suggestions without having to do major surgery?
