2014 hyper
So I got a replacement 12BBS. Filled it as per instruction and waited min 20 minutes to charge. Using a .75 Battery Tender trickle charger. Left it on the battery overnight. Light was still showing charging after 12 hours. Solid red. Should do green. Do I need a different charger. Any input appreciated. Battery reads 12.76 volts.
