1 - 2 of 2 Posts
I removed the two front bolts, but I cannot remove the tank. Seems hung up in the rear. Any advice appreciated!!
you need to remove the seat unit as well. Take off the exhaust hanger first, then just the 4 bolts holding seat unit on. I find it easier if also remove the undertray before remove seat until as can then unplug all the electrical connectors and seat unit then comes off easy, other wise still have all wires connected makes it little harder. If need anymore direction let me know will send you an email with pictures and step by step guide.
Good luck,
Dan
1 - 2 of 2 Posts
