Help: Oil Leak on 749
837 1
I noticed an oil leak from my 749 the other day. Had a recent low side.
So, I baby-powdered it today to figure out the source. Does anyone know what the problem here is?
Damn oil leak... finally caught up to me :(
1 - 2 of 2 Posts
As long as you dont have huge quantities leaking out you should be safe until your next oil change. If it is alot and you risk getting it on your rear tire you need to hurry up that oil change.
Drain the oil and undo those the bolts from the oil cooler. Inspect and reinstall those to the appropriate torque. There are some sealant compounds that you can use on the threads ... someone may chime in with what they are ...
No big worry I would say ...
Migrane
1 - 2 of 2 Posts
