Hello,
I've been experiencing problems starting; sometimes it turns over and sometimes all i get is a click. Have traced it to the started motor as the solenoid, wiring and battery are good. Loosened off the two rear case screws on the starter motor and noticed that some engine oil dripped out. I am assuming that there is an oil seal around the motor shaft which may be weeping and that I will have to replace it. Will the starter motor be ok once I get the shop to do this and clean out the motor?
Regards,
