· Registered
Like the title says. I have removed the hub and the 8 bolts holding the OEM CLUTCH BASKET ON THE 999. the basket is loose and only moves out about 1/16" and then it's at a dead stop. Can move in and out this amount easily. It looks like it is stuck to a bearing face I can see through the gap between seal and shaft.
Thanks in advance. Was hoping to finish the job tonight
UPDATE. IT WAS STUCK ON THE SEAL. ALL GOOD NOW
