My 2016 Multistrada 1200S shows no signs of ANY electrical power!!! No Dash activity, no lights, nothing (as if the battery were disconnected). It does not respond to the wireless Key Fob (which has a new battery) regardless of where it is held against the bike and the “emergency” switch to enter a PIN code does nothing at all.
The battery is at full charge ( LiFe), all fuses intact, power appears at the Starter Relay contact & I've checked all the connectors. The one time it showed these symptoms before (about 4 days B4 it went into full cardiac arrest), I was able to take the seat off, check all the connectors and all of the sudden, life returned. When it “powered up” it went thru a full suspension calibration and start-up sequence as if the battery HAD BEEN disconnected.
I’ve run out of things to check. Any Suggestions?????????
