I used the Rizoma mirror adapters to mount my mirrors.
Rizoma Mirror Adapter Clamp - Brembo Hypermotard
I love the stock set-up!I must be the only one who likes the stock set-up. I think the stock mirror/guards seem to go with the lines of the Hyper.
Eric
Are are asking me?Where on the bars did u mount them ? Not much room
I love it too. but they are really fragile. I am preparing the backup option.I love the stock set-up!
Yes, you can. It's worked for me for over 10,000 miles. Just put a rubber washer in between the mirror and pivot point (this reduces vibration and keeps it tight) and use a locking nut. That way you don't have to use Threadlocker. You may need new bolts as well.Thanks for the link sweFin !! On the 796's the pivot bolts on the clutch and master cyl are hollow. Instead of buying the rizoma adapters couldn't u just push a bolt through mirror then through the pivot point and put a nut on underside. There's no internal threads on pivot but it does go all the way through
