1 - 8 of 8 Posts
2001 748S, 14k miles
just completed an oil change.
ride the bike for 3 hours and then the low oil pressure light comes on and stays on.
correct oil level, no visible leaks, engine runs great
I tried 2 brand new pressure sensors, no better.
Should I have it trailered to the Duc shop?
Thanks.
Mr Leakered
Does the oil level go down in the sight glass after you start the engine?
Which oil filter did you use?
Good luck.
If I were you I would check the oil pressure using some gauge just to be sure. On my 996 the oil pressure warning light came up while the bike was idling , when I rev it the pressure was ok . This was caused by faulty oil pump. But If you haven't this problem before oil change it's probably not the oil pump issue. Just to be sure measure the oil pump presure
If there will be low pressure after you measure it with a gauge the problem may be the stuck relief valve in oil pump , becouse as you said when you start the engine the oil level goes up , but it should go down
what weight oil do you use? does the light go away when you rev it or is it only on hot at idle? if its on all the time and you tried dif sensors-stop running it and take it to the shop
1 - 8 of 8 Posts
