result of no start click, a bad ground
I was in a hurry to go ride, just came back and wanted to share what I did:
I Followed the advice posted and checked each connection, trying to start the bike after I cleaned each connection (each step), following these steps:
1 - checked and cleaned battery connections (installed a AntiGravity 12
cell 360cca battery) - seems like a GREAT battery
2 - starter cable - this is the front bottom of bike, it was VERY dirty and
corroded due to road exposure, cleaned and tightened, put rubber boot back
3 - checked starter coil, located mid bike under tank on frame post. Removed
rubber holder, cleaned both connections, they were slightly corroded.
4 - checked all connections under seat, including fuses
5 - grounds: I know there are three or four, ECU ground looked good
Then traced off negative battery cable where the ground goes
and it goes into the engine case, and in my case right next to
the Zard exhaust, once I put a wrench on the nut, it moved
very easily (first hint, it was loose). Removed screw and it was
very dirty, corroded and thus hint 2).
After cleaning and re-attaching main ground, the bike fired right up. Thus a trip to the dealer and at least $200 saved, mainly thanks to this forum and some beers and some patience.
Jan
