G
Guest
·hello, my gauge cluster on my 95 916 has stopped working/lighting up. the only thing that works of course is the speedo, which is mechanical, I am wondering how to fix this problem, or has anyone had this sort of problem???
The wiring diagram indicates that the fuse is 4D which can be found on the fuse box located on the right side frame just above and to the rear of the battery. It is mounted just underneath and runs parallel with the top frame tube.DePersio-Ducati said:what fuse are they under??
