I just purchased a full clutch upgrade....the old one was shot. I purchased an aluminum clutch hub and am not quite sure what stock hub mounting pieces to keep. There is a serrated washer, center nut, bug spider washer, and sleeve (the sleeve goes on before the nut and then the nut tightens down on this. When I put these pieces on the new aluminum hub the sleeve does not even come close to tightening down on the big spider washer. On LT's site he says that the only parts needed are the serrated washer and the nut do I tried that. Tightened down the out lip of the nut does not contact the new hub like it did the old one. There is quite a bit of space whereas on the old hub this would press against the big spider washer.
Any ideas?
LT is out for a week.
Loren
Any ideas?
Loren
