Hey guys!
I need some help!
There seems to be a problem with my 748/853.
Here's the problem:
When I'm going very slow (while using the clutch) or when I've stopped and is about to start again, the bike wants to stall. Just as I'm letting out the clutch, the bike makes a noise, kinda like a coughing noise. This only happens if I have low revs, but if I have higher revs, like 2k-3k rpms, it does'nt happen. Then the bike act normal.
I've tried to upjust the neutral rpm. it's at 1100k-1200k now, but that didn't help.
What can it be?
The bike is highly modded. Is it possible that the modding itself can have anything to do with it?
Lightened flywheel
cams
funnels
airintakes from wsbk
rods
clutch
airbox
cylinder kit
50 mm full termignoni
748 sps chip
Everything in the engine and the bike is changed. The bike was ment to be raced, but it never happend.
Originally the bike is 748s biposto 1995.
Can it be wrong chip?
The lightned flywheel?
The sparkplugs?
OR can it be that the igniton timing is wrong? Thats what it seems like to me. It fires to early.
Anyone experienced anything like this?
Other then that, the bike runs super smooth and it's super fast.
I want to ride, not have the bike in pieces!
Thanks guys!
Cheers!
I need some help!
Here's the problem:
What can it be?
Lightened flywheel
cams
funnels
rods
clutch
airbox
cylinder kit
748 sps chip
The sparkplugs?
Thanks guys!
Cheers!
