So I have just purchased the Ducati Performance pressure plate for my 02 748. After taking the original plate off and installing the new one I come to find out that the new plate does not sit compelety flush like the factory plate. I then re-installed the original plate and it goes on with ease. Why O why does the original unit sit flush and go on with ease and not the new plate. Also I did match the little dot with the basket. any advise would be great. Thanks
Mayor of Simpleton
Maybe your pressure plate bearing isn't seated.
The funny thing is that when I try to put the plate on even without the push rod it just does not slide right on like the original plate. its almost as if the teeth on the new plate just don't match up.
