My legs are long, but I lowered the shock to make the bars seem higher. I know all the problems associated with that, but it's only temporary. I removed the rear shock and used the adjustment below the blue nut to shorten it.
Funny thing is when I do the convertibar install and the bars rise to a usable level, I'll probably add to the length of the shock and make my seat much higher. Anyway there's a little adjustment there.
Also the preload can be adjusted for your height and weight, and you'll most likely drop seat height doing that. They are very high from the factory.
