I think from memory if you look along the frame rail just near where the front right hand tank mount is you will find a wire with a cap on it,two wires inside, one positive and the other negative, they only have power to them with the key turned on.
Oops... Sorry missed the 1100s part. (No coffee yet). Info below for 1200.
The factory connectors are under the gas tank (it has to come off). I haven't gotten around to installing mine yet. Then Ill have to take it back to the dealer to so they can activate the grips in the ECU. If you are considering wiring up non-factory grip heat Id look for the switched power plug on the left
side near the frame like the previous poster says. I run my GPS off that one, dont know if it will supply enough current for grips though.
