Any experience with the unit that comes with Tourmaster gear?Get an electronic thermostat which is easier on your charging system and more efficent.
I've been very happy with mine.Gerbings is what I'm familiar with, great stuff.
Thank you Bill. I went ahead and ordered the TM jacket liner with the pigtail BMW Adaptet cable. Do you think that will be long enough to reach the outlet under the seat?Check the Gear and Accessories forum. Here is a thread I started.
http://www.ducati.ms/forums/showthread.php?t=32828
+1 on Gerbings, once I got the jacket and heated gloves, as others have said, you wonder how you went without before. I like the freedom of movement and heat control the gear gives you. You don't have to haul around layered clothing. I'm not set up yet for keeping my feet warm, but that will be next. Keeping my torso and hands warm is the key, start from the core. I remember the day or two before I bought the heated gear, I took a ride in cold weather on my new Multi and it felt like my fingers were going to fall off. Enough of that, I went out and got the gear and it changed everything. Its like getting solar heating for your pool, extends the riding season.Gerbings is what I'm familiar with, great stuff.
You will just have to try it to make sure. I had to order an extension, but I think it was for the gloves, not the jacket. If I recall correctly, the jacket's controler is attached to the left leg via an elastic strap and the cable is long enough to plug into the power outlet, which is also on the left side of the bike.Thank you Bill. I went ahead and ordered the TM jacket liner with the pigtail BMW Adaptet cable. Do you think that will be long enough to reach the outlet under the seat?
I'm learning!Thanks everyone. Appreciate it. And especially you Chuck for not moving it![]()
