1 - 17 of 17 Posts
I like the option of being able to turn the headlight on & off, here in OZ we don't get that option, just wondering if any other countries do & have a factory on off switch??
On the RHS switch block theres a blanking plug wondering if this is where the headight switch would normally go??
If i can't source one i'll do what i normally do & thats mount small toggle switch in the blanking plug to do the same job. just doesn't look as nice is all.:mad:
expensive as hell but it does exist:
Euro Right Hand Light Switch
$300 to turn your headlight off? Ouch!
yea there a quite a few things I would put in line to purchase before that. It doesn't make sense that the part costs that much money. I had a euro switch in my vw and it was around 60 bucks and I thought that was outrageous and it allowed control of headlights, parking lights, fogs front and rear etc.
I guess my bike is "euro model" but it doesn't have Euro Right Hand Light Switch mentioned above.
can you turn your headlight off? If so can you post a picture of your switch it'd be interesting to see the difference and if there is possibly a cheaper alternative out there.
No, the lights are on always. I think it's because of some safety regulation.
You are more visible with the lights on.
In Finland you always have to use headlights or day time running lights.
daytime running lights—for visibility. didn't that start is europe? i don't know why anyone would like to have that off but to each his own i guess.
Discussion Starter · #11 ·
Here in Aus, ADR used to state headlights must be wired to ON permanently its recently changed, so I'd like the choice of on or off.
Exactly lights on = more visibility.
some times you want to be invisible for those few extra seconds...:rolleyes:
For trackdays. Appearantly, covering the headlight could result into melting it (yes, previous owner already did that once).
Personally, I run my high beam lights during the daylight hours for added visibility.
Don’t do that. It is a fact that that makes it harder for ‘them’ to judge your distance & speed.
I was doing that before I remembered that I had already proved to my self that it’s not a good idea.
Extra running lights do seem to help you be seen though. But I ain’t got any on my Hyper.
yes, that switch looks like what I could do with.
Beginning to think my battery is not holding charge so well. 796 battery is small. Few times recently it has been reluctant to start - sluggishly turning motor over. Early 2010 model so getting on for a 3 year old battery. Headlight sw. would usefully take that drain out of the circuit for starting.
1 - 17 of 17 Posts
