Don't have a solution but working same problem on one of my bikes. You're not alone
Richard, do you happen to have a diagram with the added relay?I have subsequently added another normally closed relay to make sure the lights are off during cranking.
The power contacts of this relay interrupt the negatives of both lighting relay coils. The coil of this relay is connected to battery negative and the positive coil connection of the starter relay/solenoid.
This means when the bike is cranking, positive is applied to the coil, thus opening the relay and preventing the lighting relays from being energised and hence closing.
Richard
Ah HA! Now I understand. Pictures are just simply much easier for me!Hi Brian,
Just modded the wiring diag to show how and where to connect the coil negatives from the hi and lo beam relays. Lines aren't too straight as i did it quickly
Richard
Anyone?OK, got a question as I start to gather the pile o parts I'm gonna need.
Do relays come in different Amperages, or Resistances?
Amperages, coil voltages, package type and pins vary.OK, got a question as I start to gather the pile o parts I'm gonna need.
Here is the article I wrote for Rapid Bikes Magazine here in Oz. It has a how to info and pics.@punch-jackpot!!will try and sort out the materials soon, pdf and diagram a huge help, thanks!
Cris.
If you don't want to make it yourself, there are places that sell complete slave kits. One I saw years ago used Panasonic relays that were slim and looked as though would fit under the tank better. This might be a better solution for those with limited electrical knowledge.
They are the kits I saw on the web.These ones?: Motorcycle H4 Relay Kits, cheap Worldwide Shipping
I ordered one of these kits, mainly because I was having difficulty finding the H4 plugs at the local auto stores and even with freight the price worked out hardly any more than buying all the components, not to mention saving a bunch of time sourcing parts and wiring etc.
