The bike is a 2010 Multi Pikes Peak. The low beams are spot on but the high beams are the worst. Mine appeared to be aimed somewhere into the sky. The road is literally darker when I activate the high beams and I can see them lighting up the tree tops.
Is this a common problem? Can the high beams be adjusted while leaving the low beams alone or do I just have to deal with it. They are useless as is.
Sophomore Member
In short, no. There are two “buckets”- left and right side. Each bucket has a high and a low beam bulb. See the owners manual for how to adjust.
Are the low beams the right legal height or the height you like! Might be a case of bringing it all down to make the high beam usable.
Low beams are fine. I do occasionally get blipped by cars but thats pretty rare. Will check the manual for how to adjust.
