1 - 3 of 3 Posts
Hi Everyone,
Due to my short stature I have just lowered the rear on my newly acquired 2004 MS 1000ds and now I need to lower the headlight beam as it is now pointing skyward. I have tried following the instruction manual by pressing button B then turning the ignition on, then using either button A or B to raise or lower the beam but nothing is happening. Does anyone know if there is a manual method for adjusting the headlight as it won't pass it's MOT as it is. Looking at some pictures of used headlights I can see what look like 2 white nylon gears on the top of the housing. Could these possibly be used to make adjustments.
Kind Regards,
Glyn.
remove the screen and the black cover panel and under that the white plastic things i think do it. i have done it to one recently, but forget exactly now. the electronic adjustment didn't last that long.
1 - 3 of 3 Posts
