1 - 7 of 7 Posts
· Registered
I recently had the left hand control switch replaced on my 01 748 due to an accident. I've noticed that when I switch to high beam, the low beam light shuts off. Should'nt the low beam light stay on? When I depress the high beam flasher switch the low beam light stays on. What I did was to reinstall the original left hand control switch and noticed that the low beam light stay on when I depress the HB switch and HB flasher. Is there an electrical glitch in the new switch? Thanks for the help.
Raymond
· Registered
my partner wired both together so they are running no matter what, "why the hell not, its my a_s on the line not theirs. You got to see me comming" he has a 04 749 dark.
· Ducati Designs
There definitely are a couple of different versions out there. You can open up the switch and just move the low beam wire (yellow, I think) to the common 12V supply terminal on the little switch pc board with a soldering iron, so low is always on with the key.
Ciao!
pg
Paul Geller
Ducati Designs, LLC
· Registered
My 916 was like this when I bought it, I modified the wiring in the switch so that the low beam stays on when switching to high beam - only needs the wire moving to another contact in the switch, about a 10 min job.
· way huge member
Yup, I modded my 749 switch so the low beam stays on when high is selected, so I have both beams on high.
To me, the stock headlights suck. It's not a power thing, it's a pattern thing. Having both on when in High Beam mode helps fill a huge hole the high beam alone leaves.
· Super Moderator
LuvDog said:
Do you know what year and model the "new" switch came from?
I'm guessing you got an switch off an older bike.
+1.
Mine was the same before modification.
I modified mine so it does the opposite.
Lowbeam shuts off when using the "pass" button, but stays on with highbeam when using the highbeam button.
The thought is that i can use the "pass" button to get the lowbeam/highbeam to wigwag oncoming traffic
1 - 7 of 7 Posts
