1 - 6 of 6 Posts
My 05 S4R has a low RPM, low speed surge.. and sometimes a hard time starting. I've cleaned the throttle bodies, it has a new fuel pump and pressure is fine.
As exbox exhaust, rexxar flash. Any potential ideas?
Do you mean you cleaned the throttle body throats or everything ? Have you run some injector cleaner ? You don’t mention spark plugs, everybody needs them sooner or later. Don’t change the plugs until after a tank of injection cleaner as the crud will end up on the new plugs.
Reactions: Rex Coil 7
Don’t dismiss the fuel. Try a different gas station.
give it a strong dose of injector cleaner and a good thrapping. then closing clearance, tps set up, throttle body set up / idle mixture is where i'd start.
Discussion Starter · #6 ·
Sage advice!
<img src="http://www.ducati.ms/forums/images/Ducati_ms_2015/smilies/tango_face_smile.png" border="0" alt="" title="Smile" class="inlineimg" />
Good call, I'm going to try and run this tank low before I refill it.
The bike was a barn find I rebuilt, I honestly haven't checked the plugs. I'll inspect them and fun some injector cleaner
1 - 6 of 6 Posts
