Does anybody else have a problem puting the ST4S in neutral or is it a normal situation with it?......I have to try at least 4-5 times before it finally gets into neutral, and by then the light turns green.
I have when the clutch was in need of a good bleeding.
Change out your fluid and be sure you get ALL of the air out of the system. You'll be glad you did.
