1 - 20 of 173 Posts
Hi there...
Well, my SF (Frankie) is in the final mod level.
And the final part i have to place is another handlebar :think:.
I want to replace the OEM handlebar with another, black ... but motocrosssss HandleBar.
Do you have any suggestions?
I would really appreciate it!
Thank you in advance.
Dimitris.
You could order one of the 2012 OEM bars. It shapes upwards more and would be more comfortable. You'd have to powdercoat it, though. It's like $245.
The Renthal 814 and the Rizoma bars will allow the original cables to be used with a slight re-routing. Taller ones won't. I have the 814s, and they work for me.
Not to say the obvious, but the higher up your bars get the more you're up in the wind, and starting to lose speed due to buffeting. For me max mph on stock bar is 140, but the Rizomo 008(high bar) is tops for me120-125, and with the higher seating position you are taking your bike farther away from handling like a sportbike.
Discussion Starter #9
due to my height (1.81m), i think that i have to use a mx handlebar (+) and remove height from my seat (-).
My body will hug the bike, make it easier to response.
Moreover. i dont want to remove any cable.
Just put another handlebar.
So the options that fit my needs, till now, are closer to
Renthal Fatbar Handlebar - Black 814-01-BK
and Driven Meteor Colored 1 1/8" Handlebar
Oh... can i fit also this extra bar in these handlebars??
:confused:
What are that for brand/type? Looks nice!
:confused:
This would almost certainly obscure your gauges, and I can't say I'd be happy with the aesthetics either......to each his own though :)
I think I have same bars. If so they are the Driven CF bars. They have a good bend, raise the bars up and are wider than stock. No real modifications were required. I have been very happy with them. I can sit more upright with them.
How about these?
I use OEM Hypermotard bars on my Streetfighter and love them.
Can you pat some pictures from few angles? Head on, from seat, side profile of you had side by side with stock?
Sent from my iPad using MO Free
Discussion Starter #20
there the driven cr low carbon bars. looks fantastic if your into carbon like me..
Thank you again!
my project is red-black.
So, i will not use a carbon bar but a black.
Do you know if other Driven handlebars fit in our bikes (high/low)?
Is it possible to fit this upper bar to handlebars like yours?
1 - 20 of 173 Posts
