Do you mean separate lights mounted on the handguards or using the factory turnsignals as running lights?
I´ve got some "stand alone" pods in my handguards. Works well and didnt need to do more then drill a small hole for the mounting and wires. No biggie.
You could probably get a stand alone controlbox for the front indicators and have them work as runninglights. There are afew options out there and they usually work well.
Like these: https://www.customled.com/products/blinker-genie
I highly recommend Customled, having had there rear taillights both on the MTS aswell as my old 916. A very nice solution to the problem.
Only downside is that you will need to splice into the stock wiring unless you purchase male and female sockets and solder Everything up. https://www.customled.com/collections/best-selling-products-custom-led/type-oem-connector
