thought the same thing nearly since I got the bike 2 yrs ago. just waiting for someone to figure it out. thanks for having more initiative than I apparently have and at least asking.
LOL yeah...people here come up with some stupid shit.Only in America.
+1 indeed - very tempting...I have often thought of putting a switched set of flashing red and blue LED strips on the front fairing of my bike to get knuckleheads doing 20km under the speed limit in the right hand lane out of the way...
Thanx for the link Timoz, I'm thinking of using the FALM series either the white or amber to replace the front fork reflectors. They're only 5 dollars each.Kitesurfer,
If you want to have a go I know just the thing.
I have a generic off-road bike LED munberplate light stuck on my sidecover. It is wired to my Scorpio alarm and it flashes bright white when the alarm arms. This feature is usually wired to the indicators but I decided not to do this in case it upset the CANBUS.
These things are light, waterproof, rated to run full time and are quite bright. they also moulded into a flexible rubber-like long mount that is at an angle and should provide perfect alignment if stuck onto the handguards below the indicators. The one I bought cost me maybe $14.
Like this:
You could drill into the handguard and run the wiring to the GPS power feed or headlight feed.
What about these:
AEx-RGBx RGB LED Angel Eye Accent Light Kit with IR Remote by superbrightleds.com - YouTube
They would have the cops get the rule book out for a good read.
I am sure they would be legal in Oz if you ran them white but the colour changing modes would be "interesting"
I think this would work. The turn signals on the multi work thru the ecu, it gets inputs right or left and outputs to the leds, the turn signal wiring is not connected to the canbus wiring. The canbus wiring allows the different ecu's to communicate.Got a response from signaldynamics. They say that the Tristar XP could be used for this up front, just dont connect the brake wire!
Signal Dynamics | Signal Dynamics Corporation 1-800-785-1814 | Motorcycle Safety Lights | Break Light Signal Module | Motorcycle LED Lighting | Signal Dynamics - Creator of BackOFF
Sent from my GT-I9100 using Motorcycle.com App
