1 - 20 of 27 Posts
I would mark the end of the cracks at the top side of the triple. Replace the triple if they become larger!
It was probably overtightened. I'd take the clamp bolt out and see if it cracked all the way through. It could probably be welded but a new/used clamp would likely cost less.
Hey guys,
Just noticed I have a hairline crack in my triple clamp... should I be worried about it?
Holy torque wrench! Absolutely be worried, and replace immediately. :eek:
And from the looks of that metal failure and the adjacent incorrect bolt selection, its a clear evidence of a Quarter-Turn Tony shade tree mechanic who worked on the bike previously. I'd check every engine, frame, wheel, brake, suspension and swingarm fastener on the machine against the shop manual's torque specs. Over-tight or under are both not so good...
You'll be fine if you never ride it faster than 25 mph.
t_bare
That bolt located directly below the cracks supplies the clamping force for the connection to the steering stem. The cracks were definitely caused by excessive torque on the bolt. So now, there's an inadequate (indeterminable) connection being made. Replace the triple clamp.
Discussion Starter #14
Hey guys,
Ok got a used triple clamp and seapped it out. Tightened to 123 in per pound i believe thats same as 14nm can anyone confirm?
Thank u
Discussion Starter #16
Hey guys,
One more question, what do u mean incorrect bolt selection? Thanks
Hey, thanks for reply. I hot a used one and torqued it to 123 in per lb, it seems like that was barely tight. Can anyone confirm this?
Thanks again
Cannot confirm the exact figure but, it's a pinch bolt. That is an entirely different application (much lower torque/clamping) than one that is clamping solid pieces. 10 and a bit lb/ft is probably right.
Reactions: xracer
They are pinch bolts and DO NOT NEED lots of torque. A mistake made by sooo many people. And on the steering nut it just need to be nipped up.
Discussion Starter #19
Awesome, then it should be correct. I did maybe just a little more than 10ftlb or 123 in/lb or 14nm
Triple clamp installed, live to ride another day.
Thanks everyone once again.
1 - 20 of 27 Posts
