I have an 06 s2r1k, went to ride today the bike started as normal, but noticed it was having erratic up and down idle, shut off to restart and when I turn the key on the guages did not light up or sweep although I hear the fuel pump priming. Turn key off and on again and guages are normal. Let bike warm off and while it starts to reach operating temp the guages do a full sweep while the bike is running. I take it for a test ride and while going a mile down the road guages cut off for a second, yellow immobilized light comes on and engine cuts off, then guages turn back on and power is restored. Back in driveway same thing over and over but now it takes about ten times with the key to get power to the guages. Bike will not start. Does anyone have any idea what I should be looking for?
Things I checked:
Fuses all good including voltage regulator fuse
Battery (1.5 years old). Keep on tender and when I hooked power pack to battery to jump, still no power to guages. Terminals tight
Checked for loose wires, from what I felt and saw, did not seem like anything was loose
Fuel pump and relay replaced last season, thought this may be causing a problem but last year when it went the guages were fine, just would not run without cutting out
Yellow immobilizer light is blinking as normal
Visually checked main and ignition relays, not sure what to look for although one was slightly loose, tightening it did not help.
Thank you in advance
Best
Mike
Things I checked:
Best
Mike
