Vendor
Grip Puppies bring you added comfort, better throttle control and also reduces fatigue created by vibration. A soft, squeezable grip that simply slips over your standard rubber grip (no need to remove standard grip) and leaves you with a soft, squeezable, tactile grip that will give greater comfort to any bike as well as reducing vibration through the grip.
Only $18.99 :wink2:
Check out the Grip Puppies here!
Might give these a try on my ST2. I need something to increase the diameter of the grips, mainly.
I use them on my Multistrada and definitely rate them highly.
I have pretty big wanking spanners so they increase the grip diameter just enough, they also don't effect the heat from the heated grips.
Great product.
Sent from my SM-G960F using Tapatalk
