Yours looks to be exactly what I am looking for, which is it? With it mounted to the steering stem is it easily removable? I don't necessarily want it on there all the time.
Thanks for the help.
Sorry, just read the rest of your original post and realized you have the same CycleCat set-up as I do.
If you have the CycleCat triple clamp I imagine you have the same cut-outs as mine. If that is the case I can tell you how I slightly modified the Techmount handle bar clamp to work with the CycleCat triple clamp.
The round handle bar clamp that comes with the Techmount is 2 pieces that bolt together around the handlebar. Instead of using the bolts that came with the Techmount I purchased extra long bolts (twice the length).
One half of the round clamp goes underneath the triple clamp and the other goes on top. The extra long bolts go through the cut-outs in the triple clamp and bolt the round bar clamp together to the triple clamp. Now just bolt the rest of the mount to the clamp as you would if it were on the handlebars.
Hope that makes sense, if you need some pics I can provide them.
