GPS for the Streetfighter
19949 Views 48 Replies 21 Participants Last post by  Masonic_Inc
7
Since I rode my bike 1200 miles away from home I found the need to mount a GPS unit to my bike. I wanted to keep the look as OEM looking as possible. Here is what I came up with:
I found the best place to mount the Garmin was to the steering damper clamp. I tig welded a 1/2" piece of alumium rod to the factory clamp and drilled and tapped it:
Unfortunately the alloy used on the OEM stabilizer clamp was super hard to get the heat right and burned through quicker than I could say oh crap! Since this was a non critical part I decided to fill the ugly weld in with with metal filler and finish the part.
With the Garmin quick release bracket mounted. These were test fits before I powder coated the bracket and screw to match the OEM finish:
Unit mounted:
1 - 20 of 49 Posts
2
Powder coated the bracket to match the OEM finish as well as the Garmin mounting screw to blend in.
Note: This Garmin navi unit has Bluetooth which broadcasts turn by turn audio to my helmet via my Blue Ant Interphone F4 helmet headset. By far the best Bluetooth helmet unit available IMO. (Also does incredible bluetooth telephone duty as well as bike to bike, etc.) (I could not be happier with the performance of the Interphone F4)
Next I am going to wire in the power connector, traffic antenna and make a carbon fiber cover for the quick release connector for when no GPS unit is mounted.
Stay tuned.....
I say bravo...it blends in quite nicely. Make sure you take pictures of the electrical work you do for us :D
I've always been fond of Tomtom because they give better waypoint programming...I don't have a motorcycle GPS though...
Thanks James!
The Garmin connector plugs into the side of the quick disconnect and has a cigarette lighter plug on the other end. The electrical connection will be simple. The biggest issue will be weatherproofing the connections as well as the traffic info anttena parts included in the power plug.
The best thing is that it removes with a simple push of a button and can be put in your pocket. All that is left on the bike is the mount with all of the power connections built in.
Sitting on the bike has the bikes cluster and the Garmin on the same plane and looks great.
Now if I can figure out how to make the Garmin show the caller name and info while I can answer it via the helmet w/ Interphone F4 I would be super thrilled!. It will do this on certain phones, but not on mine.
It would help me decide whether I need to pull over to answer a call or not. If you decide to answer a call while riding I can tell you that the caller will NOT know you are on a Ducati with Termi exhaust and doing 65 mph.
That is another thread though...
This is not a motorcycle specific model. Garmin makes the Zumo units which are made for motorcycles and are waterproof. This was my personal unit and if it rains I will throw it in my pocket.
I am in the electronics business so I get to try many different units.
I have also used Tomtom units and have good and bad to say about each manufacturer. Garmin seems to have the most fetures, updates, etc., so I continue to have them as my favorite, but honestly it is a close race IMO.
Does the Motorcycle models (both Garmin and TomTom) do good with gloves? (since I always wear gloves when riding...would seem silly to use a GPS that didn't work with gloves)
I am also interested in the F4 Interphone...sounds like you like it. Have you tried the other ones, like the Scala, and there are a few others out there...
Gloves suck with any touch screen. Fortunately you will not want to manipulate any of them while riding. I used mine in Florida after I set my destination and threw it in my pocket (while stationary). Anyone who tries to use it while underway is stupid.
As far as the Interphone F4, I had the Scala before. There is no comparison. The F4 is so loud for the rider that you can clearly hear it over 80 mph(probably much more). Yesterday I was on the highway doing 70 mph and my wife called. She thought I was in my car. It also does A2DP audio (stereo audio from bluetooth ipod, iphone, mp3) as well as 2 telephones and bike to bike or passenger and bluetooth enabled GPS units.
The F4 has been in short supply since it's release last fall and now are getting hard to get. I looked at their products at this year's CES show and have recommended my company to become a dealer for them. I should also mention that the build quality and waterproofing is top notch.
You using the boom microphone or the flat microphone on that F4 Interphone?
(Looking at the Blue Ant website...and deciding to buy or not...seems cheapest directly from Blue Ant--$225)
I got the boom mic and it fits in the chin spoiler of my helmet.
Doublecheck that price. $241 plus shipping was the best price I saw.
Otherwise if you are not in a hurry, wait a few days. There may be another source.... :)
4
new solution
That would work too, but I did mine in 9 pics and you only did yours in 4 and mine doesn't look like the helpful hardware man built it :p
Just joking, but I wanted to keep mine as close to the bike as possible. I tried a ram mount and it brought it up way too high.
I am finishing up the wiring right now and will post pics when it is done.
Neat idea... I am not co-ordinated enough to ride and blab on a cell, I need to focus totally on riding this beast, it is a lot of bike!
I might be tempted to try a GPS for kicks, they are cool gizmo's.
6
I removed the cig lighter plug and covered the transformer with heat shrink to make sure it was sealed from the elements. I then covered the remaining wire with techflex covering for protection against chafing and strain.
Loosened the tank and ran the wire along with the vent tube and fuel lines.
Tapped the wire into the IGN lead at the fusebox. I generally do not like to use this type of connector, but they do make the least amount of impact on the harness and are easily removable.
Covered the tap and all connections to protect and seal out moisture. Tied the wire to the bike's harness and reinstalled the tank and side panels.
Here is a short video of the unit while moving the handlebars.
http://www.12velectronics.net/images/misc/Ducati/SFGarmin.WMV
Exxxxcellent job and great write up, we should move this to the mod section on the FAQ. A keeper!:D
Thanks!
I'm not sure how much use I will get out of it locally, but since I usually like to go out and get lost somewhere at least I can find my way home.
This unit also has a nice dashboard with mileage, speed, averages, etc. that will probably get some use.
I have the Zumo 660. It's a very nice unit, very overpriced, but nice. The RAM mount that comes with it was a very pleasant surprise - very sturdy and a clean install on the mirror mount.
The Zumo's have a motorcycle mode which, among other things, makes all the buttons very large on the pressure-sensitive screen, so it works with gloves very well.
I wired mine to that exact same wire under the seat. However, I really, really don't like that style of connector you used. They tend to damage and break many of the copper strands of the wire you're splicing in to. They don't seal out environmental contaminants, either. They will work for an emergency fix, but over time I've seen the copper corrode and the connection fail on many of these. Solder it and wrap in heat shrink, or electrical tape if you can't get any heat shrink on it. Soldering is the most important thing. I recommend going back in and soldering it while the parts are still fresh in your mind, because if you're like me and you put it off, it will just keep on getting put off until it becomes a problem.
The GPS on the bike is great. Once you've got it installed, you never have to worry about the logistics of looking at a map or remembering directions.
So what's the word Duck? Gonna be a source?
I'd been wondering how to mount a GPS on the SF. My F650GS has acres of room. thanks for the writeup!
1 - 20 of 49 Posts
