1 - 6 of 6 Posts
just got them today and it doesn't have instruction with it.
I'm trying to figure out. please recommend.:D
oh, it's for 2004 749s which is 9005 type.
Plug in the two skinny cables together (obvious), bike wire to the thicker cable, the other end to the ballast (block)
thank you so much
By the way, does it need to connect to battery directly? (or just connect to low beam connector)
:confused:
yes adding a relay to the system is really simple and it will help keep from melting wires as well as the lights will actually be brighter.
1 - 6 of 6 Posts
