I'm still trying to figure out how to post here. It looks like I need to check the tab next to do anything. That has been my whole "hold-up' with contributing. Lol. First up are my front axle sliders made of delrin with a recessed aluminum hex head posts . I made them to resemble the motivations but made some adjustments. No threaded rod sticking out the end(left pics are motivation. Right are mine)
Next up is a shifter arm I made. The piece started out as the cheap Chinese lever but i made a billet arm and modified the rocker. I also drilled and tapped the foot peg for some grub screw cleats. The placement of them maintain the structural integrity and also allows me to pop the rubber I set back in. The cleats are low enough that the rubber sits higher when the 2 are together.
Next is a quick throttle lock.
Them some car on fiber pieces I made. Not perfect but I'm happy with my first attempts. I am using wet lay up over a form with vacuum bagging, release film, absorbent matt and heat. Then separate the piece, trim and finish the piece.
Then there are my Strada bags. I like my Shift-tech exhaust turned up. Because its turned up the exhaust gasses hit the bag and melt it. I heated up the bag and pressed a cylinder into it them made a carbon fiber plate to cover the Indentation and add a little pizzazz
There are a few other things but that's some of the stuff
